I picked up this fully operational Bell and Howell 173 time and motion study 16mm film projector. This model appears to be a good candidate for transforming into a 16mm film scanner for a few reasons.
This projector is already designed to be slowed down, stopped, reversed, and also includes a hand crank for manually winding the film frame by frame.
The lens on this projector comes right out and there is a clear opening for a camera to look directly inward. And there is also an opening behind the lamp as well.
This projector does not appear to be too complicated with a ton of wires and electronics to sift through.
I have been looking at different scanner designs for about a year now. I only have very basic knowledge in working with Arduino and raspberry pi but would love to learn more.
I make movies in all formats, develop film in my basement, and it would be nice to start scanning my own film instead of sending it out.
Here are some images of this projector I just picked up. Any input on where to begin would be much appreciated.
I still question whether I should just keep this projector as is and not alter it, but instead build a scanner from scratch with 3D printed parts.
I am also actually fine with very basic scans. I don’t mind starting with a 1080p Raspberry Pi camera.
Your projector is a real museum piece; it’s almost a shame to take it apart to build a scanner.
However, as you mentioned, the projector has a hand crank that allows you to advance the film frame by frame. I think it would be easy to attach a motor to that crank to advance the film frame by frame during the capture process.
In this group, you can find several examples of scanners that use vintage projectors for film transport—for instance, my own scanner: My telecine machine
I first learned to use a Raspberry Pi after starting to build my second scanner, so don’t worry. The forum has plenty of good projects to learn from.
Building a scanner from scratch is a bit more involved. And much more rewarding when you get it working. It takes 80% to get it working about 80% right, and it takes another 80% to get the reminder 20%
Like riding a bike, it is hard to learn unless you try riding one. Here is a suggestion to get you started:
Get the HQ camera, a good lens, and the optical setup (tubes and adapters). If you need specifics, I have the 16mm setup for the HQ and can make you a list.
Set a simple backlight.
Do some capture testing. For me, the learning curve for the RPi camera library was a challenge. To just test and experiment, feel free to use my current software. With a fresh OS install, it will install and run with 1 command and about 5 minutes wait.
To get a feel for what a scanner from scratch takes… design (or download) and print a guide roller.
