# Required shhutter Speed
**URL:** <https://forums.kinograph.cc/t/required-shhutter-speed/834>\
**Category:** Uncategorized\
**Created:** [May 27, 2017, 8:01am UTC](https://forums.kinograph.cc/t/required-shhutter-speed/834 "2017-05-27T08:01:39Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Udayarangi](https://forums.kinograph.cc/user_avatar/forums.kinograph.cc/udayarangi/32/927_2.png) [@Udayarangi](https://forums.kinograph.cc/u/Udayarangi)\
**Post date:** [May 27, 2017, 8:01am UTC](https://forums.kinograph.cc/t/required-shhutter-speed/834/1 "2017-05-27T08:01:39Z")
</div>
If I am using continues motion, what would be the required shutter speed/ flash duration to arrest the movement and get a sharp image. Has any one tested this?
Thanks.
**Author:** ![vintagefilm](https://forums.kinograph.cc/letter_avatar_proxy/v4/letter/v/e36b37/32.png) [@vintagefilm](https://forums.kinograph.cc/u/vintagefilm)\
**Post date:** [May 27, 2017, 12:35pm UTC](https://forums.kinograph.cc/t/required-shhutter-speed/834/2 "2017-05-27T12:35:36Z")
</div>
I have zeroed in on 20 microseconds as ideal. However to achieve this fast a shutter, you need a boatload of light. 20 works well on lighter film, but if the film is darker, it is not well exposed at 20. I am building a new 400watt light to get to 20 consistently. I have used as high as 180microseconds with good results as well.
**Author:** ![VitalSparks](https://forums.kinograph.cc/letter_avatar_proxy/v4/letter/v/73ab20/32.png) [@VitalSparks](https://forums.kinograph.cc/u/VitalSparks)\
**Post date:** [May 27, 2017, 5:26pm UTC](https://forums.kinograph.cc/t/required-shhutter-speed/834/3 "2017-05-27T17:26:08Z")
</div>
I covered this in a thread that I started a while ago. If you trawl down the thread, you will come across the results of my research summarised in an Excel spreadsheet.
> [@My approach to improving the Kinograph](https://forums.kinograph.cc/t/my-approach-to-improving-the-kinograph/145):
> 25 years ago, back in the days of Betamax, I attempted to archive my large collection of 8mm home movies by recording them ‘off the wall’ with my newly acquired (and hugely expensive) Sony SL-F1 system.This was relatively successful, mainly due to the fact that the camera had a Trinicon imaging tube which had long persistence by today’s standard so virtually eliminating flicker. Most TVs in those days rarely exceeded 21", and everything was in SD, so the result was quite acceptable. However, I k…
Jeff
**Post date:** [May 28, 2017, 3:22am UTC](https://forums.kinograph.cc/t/required-shhutter-speed/834/4 "2017-05-28T03:22:55Z")
</div>
Thanks guys for the quick response.
Jeff’,
Trying to absorb all the information from that thread.
**Post date:** [May 28, 2017, 4:53am UTC](https://forums.kinograph.cc/t/required-shhutter-speed/834/5 "2017-05-28T04:53:02Z")
</div>
Is there any other threads about your project? I specially like to know about your approach to keep a constant transport speed.
Thanks.
