Hello everyone, so to please @matthewepler , here are the two machine we’ve built to turn 30,5m of double super-8 into 4 times 15m of super-8 to load reloadable cartridges.
We decided to give it a try when we saw that Foma was factory selling for 27€ a reel of DS8 30,5m. That meant : 6,75€ of film + home processing + home telecine = A super-8 cartridge would cost around 10/12€ from raw film to digital files.
Here is the Slitter : The 30,5m of DS8 goes on top left corner, the reception of slitted film goest on the two 3,5m x 8mm reel on the bottom right corner. The slitter is a lomo one i bought on ebay for 20€. I had to turn it around because the splitting was uneven and it now goes better, beside the motor jamming because of the film resistance, so i’ill give it a try at 1/2 of it’s power instead of 1/3.
And the Counter/Cutter, made from an old “pisteuse”. The film goes from left to right through a film counter. On the left, you load a Super-8 x 30,5m reel, the film must be unreeling on the right, perforation toward the operator, emulsion on the inside. It goes to a super-8 cartridge core on the other end, screwed between two sheet of blach paper to prevent the core to turn on itself because of the film tension. Using an Infrared vision goggles, you turn it off around 3500 perforation. At that moment you unscrew and take your film on core between the two sheets of paper out ant put it in a can. Repeat with the second half. Dont go over 3500 perf, or it will jam. You will have around 50cm of leftover film.
Now, load into lubrified Wittner-Cinetec cartridge MkI (around 25€ each, without core and lub). I tried the lomo Kacemma, but it was never a success… You have to cut the notch according to the ISO you want : the two cartridges on the left are notched at ISO 100, the two on the right at ISO 40, there is no lower notch, this mean the film stock is daylight.
I’m open to questions and suggestions !
Have a nice day !
Jeremy
The metal work was only with a metal handsaw and some drilling, some rookie level stuff !
