Here is a small editable
Avisynth script, to import sequences of single image files into a video editing and encoding software like VirtualDub or Avidemux.
All you need is Avisynth 2.6 and the FFmpeg plugin for Avisynth.
Once installed, you can create a new .avs file and paste the script in it.
If the video and audio variables are set proper, the script could be opened as a video in
VirtualDub and other video editors.
[quote]#
#LoadPlugin(“X:…\ffms2.dll”)
#for the case, that avisynth does not find the FFmpeg plugin
#video variables
startframe = 0
endframe = 0
lcdigits = “%07.0f”	#enumerate images files with 7 leading digits
framerate = 24
v_dir = “”		#directory of the image files
v_filename = “”		#name of the image files
v_filetype = “”		#file type of the images
#audio variables
delay = 0		#audio delay in
ms
a_dir = “”		#directory of the audio file
a_filename = “”		#name of the audio file
a_filetype = “”		#file type of the audio
#load video
inf=FFImageSource(v_dir+v_filename+String(startframe, lcdigits)+v_filetype)
v_width = inf.Width
v_height = inf.Height
v_type = inf.PixelType
video = BlankClip((endframe-startframe), v_width, v_height, pixel_type=v_type).KillAudio()
video = video.ScriptClip(""“FFImageSource(String(current_frame+startframe, v_dir+v_filename+lcdigits)+v_filetype)”"")
video = video.AssumeFPS(framerate)
#video filters
#video = video.Levels(0,1,255,255,0)	#converts video from negative to positve
#video = video.ConvertToRGB()
#video = video.ConvertToYUY2()
#video = video.ConvertToYV12()		#only color space supported by avidemux
#video = video.Spline64Resize(720,576)	#resizes video to given resolution (SD PAL), width = 720, height = 576
#video = video.TurnLeft()		#rotates video by 90° counterclockwise
#video = video.TurnRight()		#rotates video by 90° clockwise
#video = video.Tun180()			#rotates video by 180°
#load audio (if present)
“” != (a_dir+a_filename+a_filetype) ? Eval(""“audio = FFAudioSource(a_dir+a_filename+a_filetype)”"") : Eval(""“audio = BlankClip()”"")
dubvid = AudioDubEx(video, audio).DelayAudio(Float(delay)/1000)
#audio filters
#dubvid = dubvid.Normalize(1.0)		#1.0 for peaking at 0dB
#dubvid = dubvid.ConvertAudioTo16bit()
#dubvid = dubvid.ConvertAudioTo24bit()
#dubvid = dubvid.ConvertAudioTo32bit()
#dubvid = dubvid.ConvertAudioToFloat()
#dubvid = dubvid.ResampleAudio(48000)	#resamples audio to given sampling rate, spr = 48kHz
return dubvid[/quote]
Example:
[quote]  #
#video variables
startframe = 0
endframe = 1000
framerate = 24
v_dir = “X:\video”		#directory of the image files
v_filename = “video1_”		#name of the image files
v_filetype = “.dpx”		#file type of the images
#audio variables
delay = 875		#875ms are 21 frames at a framerate of 24fps
a_dir = “X:\audio”		#directory of the audio file
a_filename = “audio1”		#name of the audio file
a_filetype = “.wav”		#file type of the audio [/quote]
If the audio variables are left as in the unedited script, the video will be opened without
audio. So the audio can be added via the video editor or encoder
