Are you looking for a camera that can capture high-quality images of fast-moving objects with close to zero motion blur along with the ability to connect to a host using a USB interface?
Introducing e-con Systems’ See3CAM_24CUG, a USB 3.1 Gen 1 color global shutter camera that comes with AR0234, a 1/2.6−inch 2MP global shutter CMOS color image sensor.
This Plug-and-Play USB 3.1 Gen 1 camera is also backward compatible with USB 2.0 host ports. The ISP and sensor settings have been fine-tuned to generate best-in-class video in both uncompressed UYVY and Compressed MJPEG. Also, its external trigger support helps to synchronize the camera with other sensors such as IMU, LIDAR, GPS, etc.
Both global shutter and high frame rate make it suitable for applications such as License plate recognition, Autonomous mobile robots, Gesture Recognition, Robotic Vision, Drones, Barcode Scanner, Factory Automation, Conveyor Monitoring Systems, and Traffic Monitoring Systems.
