I got my FLIR Oryx 5.3K (IMX530) and was surprised that it gets HOT pretty quickly with just power to it, not even capturing frames.
The camera dimensions are 60mm(W) x 60mm(H) x 115mm(L) so I ordered an aluminum heatsink 60mm(W) x 150mm(L) x 25mm(H) which I will cut to 115mm and add 2x 60mm Noctua fans on top. Thinking of bolting that heatsink assembly on top of the camera. The camera will also be bolted on an aluminum plate which should help diffuse heat a bit as well.
Is this a good plan? Wondering what you guys are doing for camera cooling?
