Wondering what I would use to externally trigger? There’s no decent examples online
If you read my previous post then you would also know that I already have a plan to manually trigger it based off the advance mechanism
Maybe using a laser will work with your planned setup as well? Laser-based sprocket registration
You can probably use a magnetic reed switch triggered by a magnet on the shaft driving the shutter and claw. See https://youtu.be/cv4aX46CCT8 for an example
