Hi, I am Mike and this is my telecine Super 8 story…
- 2015: Modified a Chinon DS-300 projector. Added motor control and led lighting, removed butterfly, added mechanical trigger and as impel webcam (Logitec C270), with a cheap lens to project on webcam sensor. Managed to create a movie but resolution was poor compared to the original film. Also images were often over exposed.
- 2016: Replace webcam by a HD webcam too boost resolution. Experimented with lighting, laser triggering. Unfortunately no improvement i.r.t. image
- 2017-2020: Decided to developed a new better prototype based on Filmfabriek design.
- Transport:
- Used stepper motor controlled by Arduino. Able to scan continuously or discontinuously (still frame)
- Trigger:
- Made laser trigger. Working perfect.
- Laser sensor provided with pinhole cover as to improve laser detection accuracy
- Optics:
- Acquired a Schneider-Kreuznach, componon-S, 2.8/50. Unfortunately it did not provide sufficient sharp images in combination of below cams. Switched over to a El-Nikkor 2.5/50. Also this lens strangely (other do with both?) does not provide sharp images with the below cams.
- Cam:
- Using BFS-U3-120S4C-CS (Flir) with very high resolution MVC (rolling shutter). Pixel size at 1,85 um seemed to be too small. Nyquist issue according to EO? Did not manage to get a sharp image.
- Switched over BFS-U3-50S5C-C (Flir) as to this cam has global shutter and larger pixels (3,45 um). Unfortunately still no real improvement in image quality after hrs of testing/experimenting.
- Controlling the cam appeared to be not easy. Also the image quality is poor (unsharp, over exposured). I wander what setting other Blackfly users (if any) use.
- Lighting:
- Experimented with different sources, diffusors etc. Unfortunately no real improvement. Cam sensor has clearly problems with the high dynamic range of the lighted film.
- Currently built (not yet tested on cam) a single RGB power led system controlled via FET & arduino. Leds can be switched on/off separately (if needed). Leds on/off is currently triggered by laser/arduino. But currently I am looking for a way to trigger from a PC (own written cam software) instead of from the arduino as to be able to adjust the RGB individual timing per frame per channel based on read histogram info (per frame). So this approach is to (and I understood Frank Vine uses this principle) a) do a RGB flash to capture the cam response (no image is saved) = histogram data, b) adjust the RGB exposure times based on histogram statistical assessment and c) flash again with adjusted RGB levels and save the image. The ‘secret’ of Frank lies in the algorithm he created that determines the individual RGB channel adjustment(s) after the first flash.
- I am thinking of creating my own algorithm. For this I am currently reading about exposure, histograms, clipping, etc. as to come with a solution that I can test. Parallel I need to find out on how to ready histogram data (from a PC/prg) and write (also from same PC/prg) a timing to the leds (via a PCB?).
- Image processing:
- I would like to prevent going the HDR route (more complex). I rather take one correct(ed) image.
- I know how to create an AVI of many images post capturing. But I have no experience on doing this on the fly. Is seems possible it can be done with the Flir cam. Needs investigating.
- Transport:
Appreciate any feedback or help with my challenges. Open to share experience.
Gr,
Mike
