My all format scanner
With the following constrains:
Camera a2A2600-20gcBAS at 100 microSec shutter
Film edge-to-edge overscan
Film speed 16fps
For 16mm and Standard 8 the calculation works to ~2 vertical pixels. In practice it would be lesser or equal to 3 pixels. Note this is not the worst case, which would be if instead of over scanned, the film is cropped at scann.
That may be further reduced if the flash is less than the shutter.
That is basically the effective vertical resolution. If one prefers a crop scan, set a vertical overscan percentage, and it is simple math from the sensor vertical resolution.
Yes, that’s right. The calculation is straightforward if both the capture height and the vertical overscan percentage are known. By “the labels ‘2K’ and ‘4K’” I simply meant that they alone do not give that information.
Imo the mechanical stability of the scanner is still important since any relative movement between the film, the lens and the sensor while the exposure is taking place can cause extra blur.
I also have a question regarding the lighting—if LEDs at different positions are used in sequence, could the change in the position of the light source cause slight apparent shifts between the individual captures and result in additional blur when the captures are combined?
(This also applies to captures taken with the film stationary)
You can make the light be at the same location for all 3. For example, using an integrating sphere.
The displacement of LEDs may be an issue for light uniformity, more than for shifts between separate captures.
The actual issue on all forms (color/monochrome white/RGB led) is that the focus point for each color channel is slightly different. If one wishes perfection, the focus point would be different for reds, greens, or blues. Again, the same issue regardless of sensor or light type.
I agree that illumination uniformity is a concern, but could different illumination angles also cause slight image shifts, particularly if the film is not perfectly flat or precisely in focus? I wouldn’t rule that out without testing it.
Or mount the LEDs on a pivoting arm so they can be positioned beneath the film frame one after another for each capture, but that starts to get a little complicated.
Ultimately, we’re still missing the definitive comparison: scanning the same film with the film stopped at each frame and multiple exposures per frame, versus scanning it with continuous film transport and a single exposure per frame, using the same camera and lens in both cases. The results should be compared both before and after post-processing.
Step by step with some small modifications I continue at free time to build the scanner
I really appreciate when you post photos. I’m building mine and a lot of times I’m looking at the photos and videos to check some details in the construction. I would really appreciate if you could post more close up photos of the different parts of the scanner. Could you also post your laser holder please.
Thank you very much for your interest. I’ll upload a closer photo of the fiber switch and the files for the three files I modified to put in the angled switch.
Arm Base 06 Laser 1mm.stl (67.3 KB)
Arm Base A3 40x40.stl (201.3 KB)
Arm Base 01 A1.stl (31.7 KB)
I would ask you if you could upload this file (Tendeur sur rail MGM9 avc ressort caché) in step or stp format. Also, since it’s easier to make some small modifications if needed, the files Essuie film antipoussière, Group Motor, Porte laser, Poulie guidage v3, Potence Eclatee as well. After that, I think all the files of the scanner will be on the forum in stp or step format.
Eldi, Would it be possible that you can post the files for your Laser amplifier case. Are you using Keyence ones or the Cloweit that you posted before?
I use Cloweit and I use Rolland’s files except for one modification on the arm. For convenience, I’m uploading again all the files I use for the pin register switch
Porte laser Knob 02.stl (3.9 MB)
Porte laser Knob 02 small.stl (2.4 MB)
Porte laser Knob 01.stl (64.9 KB)
Porte Laser case.stl (113.2 KB)
I have gathered the STEP (.step) files for the scanner here, so you can find the parts you need without having to ask me for them one by one.
I have also included several contact sheets showing earlier versions and ideas that didn’t make the cut, covering 136 archived STEP files. Since 2022, I have designed, tested, and reworked parts—sometimes starting completely from scratch—with the constant goal of improving the scanner, while also having some fun along the way.
It may be far from perfect—at least in some people’s eyes—but over the last few years, it has successfully digitized hundreds of kilometers of film in various formats, without a single breakdown. Much of what you see here is the result of real-world use and the adjustments that proved necessary over time.
I am very curious to see what different approaches others might take. Perhaps you will come up with a simpler solution, solve a problem in a different way, or conceive of something I hadn’t even considered. That is precisely why I am sharing these files, and I look forward to hearing your feedback.
All Step for the scanner
Electronics
https://chk.me/Hyoovng
Rolland, thank you so much for all the work you put into building the scanner. You’ve spent a lot of time and tried different ideas, as can be seen from the sheets of previous versions. Your machine has been tested and, as it seems, works very well. As you saw, I follow your build closely because I know it works. I need the STEP files for small changes since, as you see, we can always find the same parts but similar ones that have different dimensions. Also, with regular use, there’s always the temptation to make improvements that work—or sometimes might be worse, resulting in being discarded. In the end, the fact that you uploaded the files will be useful to everyone and also means we won’t bother you all the time. Every good and proven idea is welcome for testing. For example, HDR capture, reading optical sound from the ScanFilm program, or some module for magnetic sound.
You rock! Thank you, Roland!
@Roland Thank for you for sharing all your hard work. Much appreciated.
Epic. Thank you very much for the big work you have done
Hello Roland, thanks for sharing all files. I already started to build your machine with some adaptations linked to some materials I have from a previous 3D printer.
I have some questions concernig the lightning:
  • I suppose the integration sphere is printed in white material, have done any post treatment like painting for ex?
  • Concerning the concave mirror, can you share the specifications and the supplier name?
There’s a problem here. When I search for the part on AliExpress, I can now only find 52 mm concave mirrors, whereas mine was 48 mm. If anyone finds one elsewhere, or has come up with another solution, it would be great if you could share it.
As a last resort, it should be possible to 3D-print this part in white.
I didn’t apply any special paint to the inside of the sphere, but I did paint the outside black to prevent light leaks.
Roland, thank you for all your meticulous work!!
