Below is a system diagram showing how I intend to control film speed, tension, camera shutter (framing) and backlight flash. It is not a scale drawing, and only shows the system components in the context of the tasks they need to perform. In particular, the film gate area is only conceptual, but it is my intention to keep the film path as straight as possible to reduce drag and reduce film stress.
The heart of the system is a Phase Locked Loop (PLL) device that will probably be implemented in an Arduino, along with the tension controls and user interface.
PHASE LOCKED LOOP (PLL)
A Phase Locked Loop is a simple device capable of synchronising two signals so that not only do they have exactly the same frequency, but they also have an accurate timing relationship between each other (known as ‘phase’). A PLL can be constructed in both hardware and software, and many millions of them are in use constantly all over the world empowering such diverse things as communication and entertainment devices, to automobile systems, sattelites, and heart pacemakers.
These devices can use either analogue or digital techniques, depending on the application. In the case of the Kinograph, I am using digital which is normally used to synchronise two pulse generator circuits. However, in the Kinograph one of the pulse generators has been replaced by a combination of the take-up motor, the film, and sprocket hole sensor. In this way, the speed at which the sprocket holes pass the sensor is synchronised to the rate at which pulses are produced by the pulse generator (our speed controller). Further more, frame alignment in the camera can be adjusted electronically by changing the phase between these two pulse streams. Because of the inertia of the take-up motor,and film reel and smoothing within the PLL, this system will act like a ‘flywheel’, and be tolerant of missing or broken sprocket holes. For more information, there is a detailed technical discussion on PLLs on Wikipedia.
MOTOR CONTROL
Both take-up and supply motors are DC permanent magnet motors and they are driven by constant-power circuits. This is to aid in maintaining fixed tension regardless of the diameter of the film on the reels. Some simple maths illustrates this :
So, if the film speed is doubled, then the supply reel power must be doubled to restore tension. If film speed is fixed, then the power can be pre-set, but if a range of speeds are required then I show a tension measuring device in the form of a ‘dancer’ which feeds back to the motor to maintain original tension.
There is an additional facility to stop the system if there is a film break, jam, or end of reel is reached. For this to happen, both the dancer will have sensed unusual sustained tension and the PLL will have dropped out of lock.
Because the two motors are identical, it should be possible to reverse the film direction, and fast rewinding should also be possible if the film is passed through the centre rather than around the dancer rollers. Also shown are two Particle Transfer Rollers (PTRs) which attract particles of debris from both sides of the film.
OTHER COMPONENTS
The ‘dancer’ rollers are a particular challenge because they need to have virtually zero-torque-friction of their own, which means measuring their angle cannot easily be done with a simple potentiometer. To overcome this, I propose using a cheap magnetometer chip, like those inside cellphones to provide a compass. The dancer will have a small low-field plastic magnet fitted to it, which will rotate above the chip providing a continuous stream of digital serial angular data. The dancer mechanism itself will be 3D printed to operate over 90 degrees, and will have an integrated helical (spiral) spring as part of its design. I do not yet know whether the mechanism will need any form of damping.
I have chosen to use a reflective laser method for detecting sprocket holes. This provides the greatest contrast ratio, makes no difference if the substrate is black or transparent, and is the most suitable method for 9.5mm film with central sprocket holes.
I am still undecided about the design and illumination of the backlight. My preferred approach is to try using an integrating light sphere, as it promises to give even illumination and significantly reduce the visibility of scratches, but it may be difficult to find space for it.
At the moment I am only interested in films with single perforations per frame (8, 9.5, 16 mm), but I have a modified scheme for 35mm (4 perfs per frame) which should be equally viable. Matthew is currently previewing it, and I will add it here in due course.
This system I have just described is a bit of a Rolls-Royce solution, but I am also looking at a very much simpler version that has no control elements as such, but still maintains constant tension at a fixed chosen frame rate. The downside is that everything may need adjusting manually, including framing, for each film. When I have more details I will update this thread.
